Postby 9a4db » Thu Jun 25, 2015 4:00 pm
Evo ga, stari dobri CD4066 plus LED je rješenje za sve... u svakom je po 4 sklopke
a meni treba 7 + 7 segemenata plus TX i low power indikator, tj. decimalne točke.
dakle 16 sklopki u 4 chipa. Plus 2 kom LED po 7 segmenata sa dec. točkom.
Sve stane unutra na mjesto starog LCDa...
Razmišljao sam i o LCD 3 1/2 znamenke to je ovaj lijevo na slici ali njega bih
morao stavljati na kutiju izvana.
Postby 9a4db » Sun Jun 28, 2015 3:18 pm
Moderna tehnologija je tema za danas :)
Dva DSP RXa koji bi vas mogli zanimati.
Prvi jeftin a efikasan te drugi ne tako jeftin ali pokriva zanimljive bandove....
$75
http://www.countycomm.com/gp5ssb.html
https://www.youtube.com/watch?v=0hopz-5cEsU
$599
http://www.commradio.com/cr-1-cr-1a-reference/
https://www.youtube.com/watch?v=ZYKYNCLIbqU
Postby 9a4db » Wed Jul 01, 2015 8:40 am
A sada nešto digitalno a nije DSP....
https://www.kickstarter.com/projects/74 ... ransceiver
Specifications
Form Factor: Arduino-compatible stackable shield
Arduino Pins: I2C; GPIO, PWM and ADC
Frequency RX/TX: 134-174MHz, 200-260MHz, 400-520MHz
Amateur Radio Bands: 2 Meter, 1.25 Meter, 70 Centimeter
Power Output: 250 milliwatts (preliminary)
Radio SoC: Auctus A1846S
Channel Bandwidth: Selectable between 12.5KHz and 25KHz
Subaudio Modes: CTCSS, CDCSS (transmit/receive independent)
Advanced Features: Volume, Squelch, VOX, DTMF encode, DTMF decode, tail noise elimination, tone generator, tone detector, RSSI
Pre-Emphasis: Can be disabled to assist with digital modes
Antenna Connector: SMA, 50 Ohm (optional "rubber duck")
Audio Connection: Hardware selectable between TRRS (mobile phone style headset) and Arduino PWM/ADC inputs and outputs, PWM/ADC smoothing filters built in
Input Voltage Range: 5-20VDC, 4xAA, 7.4 volt lithium battery pack, power adapter capable
Postby 9a4db » Thu Jul 02, 2015 10:23 pm
Prošlo ljeto nabavio sam polovni FT817... par sitnica je trebalo popraviti
a najveći problem je bio ovaj encoder, koji jednostavno ima rok trajanja.
(Bez seta mini torx-a se ne upuštajte u to - ovo plavo)
Najvrijedniji dio na uređaju je ustvari ovaj DSP filter...
Uz prisutni nivo šuma na bandovima danas, bez njega - tko se jednom na dobro nauči, ne može.
Na linku imate, što ljudi kažu o tom DSP-u
http://www.eham.net/reviews/detail/3626
Postby 9a6r » Fri Jul 03, 2015 11:31 am
Đani,daj molim te javi mi se na moj mob... DONE / edit 9A4DB
Postby 9a6r » Sat Jul 04, 2015 9:20 am
Đani hvala na ugodnom razgovoru i savjetima.GL 73 DE 9A6R
Postby 9a4db » Fri Jul 17, 2015 6:36 pm
Eto mene malo opet....
Misli moja malecka iz bijeloga svijeta na svog taticu ;)
Na "ebaj" ovakva stvar vrijedi 100-150 USD plus prijevoz 50-80 USD,
meni došlo na kućna vrata uz veliku pusu...
RLC Electronics A-4020A DC-3Ghz, 200W, 40db Attenuator za onaj moj Agilent E7495B
To bi kao bilo kada narinem 200 W na izlazu se vidi 0.02 W ili 20 mW / 13.01 dBm, meni dosta...
Jer ->
The maximum power for the RF In (Port 1) and RF Out/SWR (Port 2) ports is
+20 dBm (100 mW)
kalibracija ->
Ovo je bazni Agilent E7495B instrument , na slici u remote modu na PC preko Ethernet IP servisa...
Postby 9a4db » Fri Sep 04, 2015 7:17 am
Ne palim lemilicu, prevruće je za to, ali zato se proučava literatura :)
https://archive.org/details/vacuumtubemanuals
Postby 9a4db » Wed Oct 07, 2015 1:26 pm
Postby 9a4db » Thu Oct 08, 2015 11:08 am
Puno, puno linkova na pdf knjige o radio tehnici....
http://www.qsl.net/va3iul/Files/Old_Rad ... _Books.htm
